Canon irc4080i dead panel
  • lwps
    • Sep 2010
    • 2
    [Electrical] Canon irc4080i dead panel
    I have an irc4080i that the control panel has gone out 2 times. Got a call this morning and it is blank again and warm to the touch. Any ideas?
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: Canon irc4080i dead panel
    First Give us a Lead here!. The first time the control panel blanked-out, What did you do?
    • lwps
      • Sep 2010
      • 2
      changed the complete panel out; worked for about one month blanked out again. Put the old panel in another machine and it works.
      • teckat
        • 16083
        does the printer still print when panel goes blank ??
        remove>CHECK>CLEAN MEMORY DIMM ENDS or Replace
        also Remove and re-seat the boot dimm
        Check your Power Supply (DC Converter) FM2-6300-000
        • arielcanon
          • Mar 2012
          • 106
          I've faced this problem, finally this problem could be solved by replacing Inverter PCB of control panel
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • teckat
            • 16083
            poster already replaced entire panel
            • arielcanon
              • Mar 2012
              • 106
              , came from another factor..., we'll see the feedback from poster, what that factor is...
