C7000vp Help E20-0385/0381/0386
  • ldharnden
    • Apr 2011
    • 47
    My last ditch effort before we replace the DC-Con. The original problem started with the 0385 code popping. I cleaned the patch sensor as stated. Fired the machine back up and started with some PG10 to get the machine rolling. After the specified 25 sheets ran it pulled the 0381 code. I replaced the sensor and tried again, same code. Changed developer housings to see if a wire harness went bad, same code. Changed drums, same code. Changed wire passthru plug where the dev housing plugs to, same code. DENS readings in level 1 show normal, print PG10's are nice and solid but the the value for the P-B-P-C referenced for the code is the same 72 versus the others that are within spec. The weird part is with all the changing it remains 72. I then ran a D-CON reset following a old post rom Teckat. After a pain in the a** time with a senior color tech re-entering the values and verifying we now get the 0386 code as well as ALL color values being WAAAAAY off. The windows values in service 1 show teen numbers, and all the P-B-P values for all four colors are showing the same negative number (at least it is consistent right). But the PG10 pages run nice and solid like the sets before, no change. Canon phone support says replace controller. Before we do that I thought I should get everyone thoughts. Anything at this point would be great. Machine is still a baby, installed in 07and has only 2.75 mil on counters. All PM's and upgrades have been kept up on and done. Running version 87 firmware. Thanks
  • teckat
    • 16083
    Re: C7000vp Help E20-0385/0381/0386
    What are the DEPOT>VFF-Y/M/C/K readings. ?
    Readings are typically between 200-300.
    have u seen the dev drive assebly gear failure pub for 7000VP series from 2009
    can cause weird e020's
    • ldharnden
      • Apr 2011
      • 47
      The VFF values are a little high but are within spec.
      I haven't seen that tech pub, I will take a look at it. Sounds promising! Thanks.
      • ldharnden
        • Apr 2011
        • 47
        Teckat- I looked over the pub. The only thing wrong with that is the copy quality isn't being effected. What we can print before the codes looks great. It is really a case of the machine seeing a problem that is not really there, in a matter of speaking.
        • teckat
          • 16083
          check the spring loaded white lift cams --front & rear side to see if they have flat spots//under Process unit
          • dkarthy
            • Mar 2012
            • 13
            Would you pls suggest
            Hi Im Karthick,
            I 'm facing the error msg E602-003in my ir3300 copier would you please suggest me how to resolve that.
            Now i,m having parallel cable which helps to connect my copier to my PC and SST V2.01. now i 'ON' my copier it went in to download mode. my PC detected my copier after that if i start my SST i cant see my copier. would you please suggest me how can i proceed further.
            I hope my Hard disk needs to be replaced. what you can advise me? and i'm using Win764bit as my OS
            Awaiting for your reply
            You could write me in dkarthy@rediffmail.com
            thanks
            • teckat
              • 16083
              Re: Would you pls suggest
              Originally posted by dkarthy
              Hi Im Karthick,
              thanks
              this is a post about C7000VP /
              RE-POST YOUR ISSUE as title iR3300 SST
              • ldharnden
                • Apr 2011
                • 47
                Teckat- I am happy to say this issue looks resolved. After inspecting the lift cams as suggested and finding all to be well. The senior guy that was working with me suggested updating the firmware to the newest (we held off due to issues previously with 13x19, but was told that had been resolved), running D-CON again, reentering all values as per previous. Didn't work... Then he had me run the sensor adjustment on service 1>function>Misc-P>Page 3 - LP-<something>ADJ (sorry just got home not in front of the machine anymore. Can repost Monday the exact service item). Once complete everything was spot on, for now. Will keep posted but thanks for all the help Teckat!
                • teckat
                  • 16083
                  good find >
                  can't wait to find out the fix u had for that error/
                  • bondz005
                    • Sep 2012
                    • 12
                    What if the values are beyond the typical, how are we going to resolve this issue?
                    It's okay in the end, If It's not okay, then it's not the end.
                    • teckat
                      • 16083
                      what are u talking about ????????? last post on 03-31-2012
                      what machine are u talking about/ ?? C7000vp ??
                      Note: there is no typical in Canon---------------------
                      if your DEPOT>VFF-Y/M/C/K readings are beyond 200-300.
                      you start looking into the effected color or colors-
                      for instance 470 may indicate a LASER issue-
                      Other items to check are the primary grid, drum wear, dust proof glass, starter condition and patch sensor-
                      following correct procedures after developer change
                      this is called MACHINE MAINTENANCE !!!!!!! CHECK !!!!!!
                      & reading a MANUAL / & understanding performance according to enviorment printer is in
                      • bondz005
                        • Sep 2012
                        • 12
                        Does anybody got the specific solution for this error. Please help...
                        • bondz005
                          • Sep 2012
                          • 12
                          03-31-2012
                          & reading a MANUAL / & understanding performance according to environment printer is in
                          Yes Sir it seems that this old problem got me hit.
                          and yes it is C7000VP MACHINE
                          my current readings are as follows:
                          VFF - Y = 377 v
                          M = 398 v
                          C = 437 v
                          K = 410 v
                          Thank you sir for the tip, are these reading indicates that this machine will soon be dead?
                          • teckat
                            • 16083
                            noun \ˈmānt-nən(t)s, ˈmān-tə-nən(t)s\
                            the act of maintaining
                            the state of being maintained : support
                            : the upkeep of property or equipment
                            and a lack of is related below ---------------------------------------
                            Near Antonyms
                            dereliction
                            disregard
                            ignoring
                            inattention
                            neglect
                            negligence
                            E020----------------x= 1:Y 2:M 3:C 4:Bk
                            E020-0x81
                            Error Description: Lower limit error in light intensity on drum base (reflecting light intensity from the drum surface)
                            * COPIER > Display > DENS > P-B-P-Y/M/C/K is less than 150.
                            Cause of occurrence (Highly possible): Soil on the ATR sensor [*1]
                            Cause of occurrence (Low possible): Faulty pressure for developing assembly
                            Broken wire of ATR sensor
                            Damaged ATR sensor
                            Malfunction of ATR patch detection shutter
                            E020-0x82
                            Error Description: Lower limit error in current passed to the sensor while the patch sensor LED
                            is off
                            * COPIER > Display > DENS > P-D-P-Y/M/C/K is 30 or less.
                            Cause of occurrence (Highly possible): Broken wire of ATR sensor
                            Damaged ATR sensor
                            E020-0x84
                            Error Description: Fault at sampling drum base
                            * A difference between the values in service mode > COPIER > Display > DENS >
                            P-B-P-Y/M/C/K and P-D-P-Y/M/C/K is 30 or less.
                            Damaged ATR sensor
                            E020-0x85
                            Error Description: Fault at sampling 1 in patch image
                            DENS-S-Y/M/C/K and P-D-P-Y/M/C/K is 30 or less.
                            Cause of occurrence (Low possible): Image density is too high.
                            Damaged ATR sensor
                            E020-0x86
                            Error Description: Fault at sampling 2 in patch image
                            DENS-S-Y/M/C/K and P-B-P-Y/M/C/K is 30 or less.
                            Cause of occurrence (Highly possible): Image density is too low. [*2]
                            Cause of occurrence (Low possible): Soil on the ATR sensor
                            Damaged ATR sensor
                            E020-0x87
                            Error Description: Upper limit error 2 in current passed to the sensor while the patch sensor
                            LED is off
                            * COPIER > Display > DENS > P-D-P-Y/M/C/K is 930 or more.
                            Cause of occurrence (Highly possible): Damaged ATR sensor
                            E020-0xC2
                            Error Description: Error in variation of sampling value in patch image
                            * When variation of sampling Sig values is 400 or more.
                            Cause of occurrence (Highly possible): Tiger stripe
                            Cause of occurrence (Low possible): Scratches on drum
                            E020-0x90
                            Error Description: Lower limit error in ATR patch image density
                            Damaged ATR sensor
                            E020-0x91
                            Error Description: Upper limit error in ATR patch image density
                            * COPIER > Display > DENS > DENS-S-Y/M/C/K is more than 880.
                            Damaged ATR sensor
                            E020-0x92
                            Error Description: Lower limit error in developer density
                            * COPIER > Display > DENS > DENS-S-Y/M/C/K is –4% or less 3 consecutive times.
                            Damaged ATR sensor
                            E020-0x93
                            Error Description: Upper limit error in developer density
                            * COPIER > Display > DENS > DENS-S-Y/M/C/K is +4% or more 3 consecutive times.
                            Damaged ATR sensor
                            E020-0xB0
                            Error Description: Lower limit error in signal value of toner density sensor
                            * While printing, COPIER > Display > DENS > SGLL-Y/M/C/K is 64 or less for Y and 48 or less
                            for M/C/K for 5 prints continuously (T/D ratio is too high).
                            Cause of occurrence (Highly possible): Abnormal toner supply [*3]
                            Cause of occurrence (Low possible): Short circuit of harness for ATR sensor
                            Occurrence of Tiger stripe
                            E020-0xB1
                            Error Description: Upper limit error in signal value of toner density sensor
                            * While printing, COPIER > Display > DENS > SGLL-Y/M/C/K is 192 or more for Y and 126 or
                            more for M/C/K for 5 prints continuously (T/D ratio is too low).
                            Cause of occurrence (Highly possible): Disconnected connector of toner density sensor (or
                            poor contact)
                            Cause of occurrence (Low possible): Faulty sub hopper (no toner)
                            Damaged toner density sensor
                            • bondz005
                              • Sep 2012
                              • 12
                              E00020-0381-05
                              This Error occurs frequently after printing 15-16 sheets or after adjusting the fixing unit, as I observed ... I just don't know what to do. thank you.
