black lines canon ir2016
  • ernesto
    • Oct 2011
    • 430
    Hi
    I have a problem with a copier ir 2016, in the display appear change new toner, but it is not necessary because the bottle of toner is full, also there are black lines in the photocopies sometimes.
    I have cleaned the antenna rod of the developer, but the photocopier only has worked one day, I am
    anyone knows the problem ? do you think replacing developing unit is a good decision ?
    I hope hearing from you
    thanks a lot
  • teckat
    • 16083
    Re: black lines canon ir2016
    Originally posted by ernesto
    Hi
    going to replace developing unit.[ATTACH=CONFIG]15028[/ATTACH]
    thanks a lot
    is that a copy of a white sheet of paper off the glass ??
    is that a paper feed direction of front to back lines ?
    Developer Unit
    • ernesto
      • Oct 2011
      • 430
      [ATTACH=CONFIG]15034[/ATTACH]
      Developer Unit
      Hi
      it is a a4 white copy without document, it is NOT a4r copy
      the sheet goes out in the direction of the arrow
      Do you think it is a good idea replacing developer unit?
      Thanks a lot
      • arielcanon
        • Mar 2012
        • 106
        Please cek this part PLATE, TERMINAL, SLEEVE, with part number FC6-4170-000. I have found poor contact this plate to bias . also clean rod antena at rear side near gears
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5011
          Fixing film can't spinning properly.Replace fixing film and use fixing grease by procedure.
          • ernesto
            • Oct 2011
            • 430
            thank you very much for your advices
            I have replaced developer unit eight days ago and the copier is working right now,
            the problem may be is "Please cek this part PLATE, TERMINAL, SLEEVE, with part number FC6-4170-000. I have found poor contact this plate to bias . also clean rod antena at rear side near gears " arielcanon.
            all the best
            Ernesto
            • arielcanon
              • Mar 2012
              • 106
              Why should change dev unit??, it'll cost u a lot of money instead of changing that part, u know the most important thing is how to make shaft connected to plate bias on rear cover dev assy. I found this plate broken, and I throw away, then I modified using a small plate so that shaft of dev assy still connected to dev bias..
              • ernesto
                • Oct 2011
                • 430
                becuse I had a second hand developer ;-)
                thanks for your tips
                all the best
                Ernesto
