canon ir C 5185 Feeder jamming issues
  • schwinnja
    • Apr 2011
    • 21
    So i've got a Canon IR C 5185 that is having issues with the feeder. Everytime someone uses the feeder it says that it is jammed. however, there are no papers inside. opening the various compartments does not fix the issue and it still says it's jammed. the only "fix" is to restart the machine, at which point there is no jammed papers in the feeder. Could this be a sensor issue? any thoughts?
  • vigour
    • Aug 2010
    • 1038
    Re: canon ir C 5185 Feeder jamming issues
    yes sensor issue, what is the jam code.
    • THUK
      • Jul 2008
      • 195
      hi i have had same type of fault and it was a PCB fault.
      • schwinnja
        • Apr 2011
        • 21
        I will be finding out the code today, as i am not currently at the office with the problem copier. what is the PCB fault? I don't know what that means.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 4999
          Did you try "sensor init"?
          • schwinnja
            • Apr 2011
            • 21
            My boss went to the office and now the copier no longer works once you put something into the feeder. The jamming issue never brings up an error number.
            I spoke with the company we purchased the copier from and they suggested using canned air to clean off the sensors in the feeder and then using additional functions and going to adjust feeder or feeder cleaning. I don't see any harm in trying the canned air on the sensors in the feeder. not sure what the cleaning function would do. what should i be looking for as far as Sensor Init?
            • zoraldinho
              • Mar 2008
              • 4999
              Are you a tech?
              • schwinnja
                • Apr 2011
                • 21
                Me? I am not.
                • zoraldinho
                  • Mar 2008
                  • 4999
                  Originally posted by schwinnja
                  Me? I am not.
                  Call one.
                  • teckat
                    • 16083
                    what DADF MODEL is on this printer>>>DADF-T1 or DADF-M1
                    DADF-T1 is DADF installed in Duplex Color Image Reader-G1.
                    It is DADF that added a simultaneous two sided reading function to existing DADF-M1.
                    A CIS unit is installed in the DADF-T1. Therefore, both-sided simultaneous reading can be
                    selected in addition to the conventional reversal both-sided reading.
                    In the reversal both-sided reading (DADF-M1), the document is reversed in the machine and
                    the CCD unit installed in the reader assembly reads its both sides.
                    In the both-sided simultaneous reading (DADF-T1), the document is fed only once in the
                    machine. The CCD unit reads its first side, and the CIS unit reads its second side at the same
                    time.
                    • copicatt
                      • Nov 2008
                      • 366
                      Could you tell me what the solution was. got this going on today. Thanks. And I am a tech, Lol.
                      • THUK
                        • Jul 2008
                        • 195
                        hi it was the main dadf pcb.
