Error codes E733 and E010, Canon ImageClass 2300
  • lonestar
    • Aug 2025
    [Error Code] Error codes E733 and E010, Canon ImageClass 2300
    I have a customer that has both these codes on their ImageClass 2300. I've heard the E010 is a main motor lock, don't know what the E733 code is and don't know what causes either. Anyone have ideas how to fix? Thank-you in advance for your help, lonestar.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: Error codes E733 and E010, Canon ImageClass 2300
    • lonestar
      Thank-you so much for your help on this one! It looks like the DC controller may be faulty. From your experience, what would you say?
      • zoraldinho
        • Mar 2008
        • 5016
        First check connectors!
        • lonestar
          Re: Error codes E733 and E010, Canon ImageClass 2300 paper jam/open front cover error
          I reseated the connector on the DC controller PCB, image processor PCB and the power supply PCB's. After powering on the machine, I received a "Rec. Paper Jam [1 - 2 - 3], Open the Front Cover" error code on display while the front cover is closed. I re-checked and reseated all connectors for the PCB's with no sucess. There are no bent pins and all connector appear correct. Please, anyone have any thoughts? Does this appear to be another symtom of a bad DC controller PCB? There was enough dust in this machine to plant onions.....
          • arielcanon
            • Mar 2012
            • 106
            I have found E733,and the solution is replaced DC control PCB & clear error
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • lonestar
              Thank-you so much for your help! Does anyone know where to obtain a DC controller for a Canon ImageClass 2300?
