changue combination *28*
  • DANIELCANON
    • Jun 2011
    • 187
    hello, es posible cambiar la combinacion *28* para ingresar al modo de servicio en una image press c1.
    quiero insertar otra combinacion para ingresar al modo de servicio . gracias.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: changue combination *28*
    Switch the method of entering the service mode lev.2
    Copier>option>body>svmd-ent
    0: Press the [User Mode] key. --> Press [2] and [8] at the same time. --> Press the [User Mode]
    key.
    1: Press the [User Mode: key. --> Press [4] and [9] at the same time. --> Press the [User Mode]
    key.
    Standard value
    0
    • DANIELCANON
      • Jun 2011
      • 187
      THANK YOU ............. ZOLANDRINO.
      • zoraldinho
        • Mar 2008
        • 5018
        • jacky_kuo
          • Aug 2011
          • 54
          are you sure iPRC1 has this item ?
          why can not I found this item in my all machines ??
          • zoraldinho
            • Mar 2008
            • 5018
            level 2 ??. Try harder.RFM
