When i print colour work it prints only black the colour does not come and when i make colour copy it also prints black. I have chang all the settings but still not working . Pls any help from gurus.
IR C 2570
Tags: None
Re: IR C 2570
orFrom the Display Panel of the imageRUNNER change the setting from "Black" to "Auto - Color" using the pull down menu.
Then Press Additional Functions
Select Copy Settings
Scroll down to select Standard Settings
Select Store ("Do you wish to store this setting?" will be displayed)
Select "Yes" to store the setting and "Done" two times to exit the Additional Function screen
option is for setting the default for Color or Black&White copies.
1) Select [Additional Function].
2) Select [System Settings].
3) Select [Color Mode for Copy].
4) Select [Auto-Color Select]. This needs to be [Off].
5) Select [use Full Color]. This needs to be [Off].
6) Reboot Copier.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: IR C 2570
Thanks teckat, i have done all that you said but is still printing only black the colour thus not print.Comment
Re: IR C 2570
can u go in System Settings ??
on the control panel/ do u see the Auto- Color option ?
AUTO.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: IR C 2570
Thanks teckat, when i print auto gradation the colours do not print only the black slips print and also i can see the auto colour copy in the configuration. And because of that it i can not do the calibration.Comment
Re: IR C 2570
if prevent color can be locked out------
this is how it's done--
To prevent Color copies from being made using Department id, follow these instructions.
3) Select [Department ID Management].
4) Select [ON].
5) Select [Register Dept.ID/Password].
6) Select [register].
7) Enter a Department ID number with a password.
8) Select [Turn Limits ON/OFF and Set Page Limit].
9) Select [Color Copy Limit] and turn [ON] and leave counter to 00000.
10) Hit [OK]
If you try to make a copy the copier will not permit you. You will get an error message: [Reached counter Limit. The printing/reserved jobs may be stopped. Check the print logs].**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
