Canon IR4570 long file
  • eng_usama
    • 115
    Help with Log file in IR4570 i want to know number of orders stores in that log ?
    and if there is away to expands that long to contains more orders please help me
  • teckat
    • 16083
    Re: Canon IR4570 long file
    what log
    • eng_usama
      • 115
      log for orders have been printed on the machine
      • arielcanon
        • Mar 2012
        • 106
        to control total number that we have printed, I use Departement ID and print page total weekly, so that we can see who is (user/id) that use printer mostly.
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • eng_usama
          • 115
          thank you all for answer .
          i am asking about log file how many orders that can be contain on it ?
          • eng_usama
            • 115
            please help me
            • teckat
              • 16083
              please help me
              To Print out the Department ID Print totals:
              1. Select Additional Functions on the Control Panel.
              2. Select System Settings.
              3. Department ID Management.
              4. Select On
              5. Select Print Totals Page Totals.
              6. Print List
              or
              The Job Log is one way to keep track of the jobs sent to the imageRUNNER for printing. It shows details such as the User ID (Network ID), Time, Application, Size, Pages, etc.
              Another way is to use a third-party software interface. One possibility is a company called Equitrac. They make a software interface that prompts you for a ID/PW when sending a print job, and tracks the print jobs as well.
              NOTE: Canon does NOT support this third-party interface.
              COPY JOBS
              In order to track the Copy Jobs, Dept ID Management must be set up on the machine. Each time a copy job is done, the imageRUNNER will prompt you for a User ID and Password. These jobs are tracked and can be viewed under the Dept ID Management located under the Additional Functions > Custom Common Settings Option
              1 Press [System Monitor] select the job type ([Copy] or [Print]).
              2 Press [Log] [Print List].
