E 733 - 0001 constantemente
  • DANIELCANON
    • Jun 2011
    • 187
    Hola a todos constantemente la maquina imagepress C1 indica dicho codigo; ya he cambiado de servidor T1 v2.0 por otro.
    cambie los cables de comunicacion y la tarjeta de interface que va en la maquina pero el codigo persiste ...
    alguna recomendacion....
  • Oze
    Ricoh Fanboy
    • 1663
    Re: E 733 - 0001 constantemente
    Google Translato..u use....o
    • HELIO240
      • Jan 2011
      • 137
      you must change the serial cable from the server, format the server again, check the connector server and the machine if the red and green LED is lighting, check the status of the network connector on the machine, replace the cable crossover.
      If you still can not resolve which intface check that this machine. Exchange server.
      • DANIELCANON
        • Jun 2011
        • 187
        ya he cambiado de servidor y de cables tambien de tarjeta de interface.....pero el problema persiste.
        alguna otra idea?
        • HELIO240
          • Jan 2011
          • 137
          alguna otra idea?
          You have to test this server with other equipment c1, so you eliminate the server. Check the air intake of the server clean if dirty and do the same with the filters in the machine. Have you thought about upgrading to the dc controller c1.
          Any new contact.
          Big hug.
            • 16083
            This E733-0001 issue was addressed in 2007 with a DCON v9.01 update
            I would re-load the DCON from SST -
            what is the System Software ver. on printer ???
            E733-0001
            imagePress C1
            Start-up Sequence
            1. Boot Program (Section 1)
            The boot program is executed by the CPU on the Main Controller Circuit Board when the Main Power Switch
            is turned ON. A check is made of image memory (DDR-SDRAM) and HDD status.
            An error code is displayed if any abnormality is detected. If everything is normal, the control program is loaded from the HDD into memory.
            2. Control Program 1 (Section 2)
            1) Each device (each hardware device on the Controller Circuit Board) is checked and initialized.
            2) System files are restored as necessary if the previous shutdown was not carried out normally. Boot-up requires more time than usual in this case.
            3) Each program module is initialized.
            3. Control Program 2 (Section 3)
            1) The initialization of each software module and configuration of the printer and scanner are completed.
            2) The start-up sequences ends if the printer and scanner are detected normally.
            If they are not detected normally, a connection timeout occurs and E732/E733 is displayed.
            Turn off the main power, and check the connectors to the DC controller PCB and the main controller PCB, and image reading unit -- check the power supply of the printer; then, turn on the main power.
            Check your READER CONNECTION TO THE PRINTER
              • 16083
              alguna otra idea?
              READ THIS PDF FOR BOARD ADJUSTMENTS ON imagePress C1
              Name of Sub
              PCB Possible Error Codes
              S-B PCB E240-0001, E350-0000, E351-0000, E732-0001, E733-0001, E747-051B, E747-0C19, E747-3C00, E747-DF00, E747-FF00, E748-4000
              PF-A PCB E241-0001, E350-0000, E351-0000, E732-0001, E747-3F02, E747-5906, E747-5F02, E747-7F00, E747-DF00, E747-FF00, E748-4000
              R-A PCB E350-0000, E351-0000, E732-0001, E747-7F00, E747-DF00, E748-4000
              • DANIELCANON
                • Jun 2011
                • 187
                la maquina cuenta con la version 21.01
                he cambiado la tarjeta de la siguiente foto pero no las otras que se muestran en el pdf.voy a hacer el intento con las demas tarjetas.Sin título-1.jpg
                  • 16083
                  he cambiado la tarjeta de la siguiente foto pero no las otras que se muestran en el pdf.voy a hacer el intento con las demas tarjetas.[ATTACH=CONFIG]15168[/ATTACH]
                  do the inspection,clean and adjust on the boards
