IR3035 on Mac OS10.4 and OS9
  • Brian8506
    • 1666
    Unsuccessful trying to install on Mac but connects to a PC. Can find UFR II driver for OS10.4 but Mac won't recognize machine. Can't find a driver for OS9. Does anybody know if this can be done. Customer currently has a 3320I hooked to Macs with no problems. 3035 has UFR II and PCL
  • KL568
    _
    • Feb 2011
    • 324
    Re: IR3035 on Mac OS10.4 and OS9
    Are you using AppleTalk? With UFRII, you need to use IP printing.
    Offhand, I can't recall how 10.4 is setup but tyy to look for something with Canon UFRII when you are @ IP printing.
    With OS9, UFRII is no longer supported.
    As for why iR3320 works, it is because is has PS option in it.
    • teckat
      • 16083
      ----MacDriverMatrix.pdf
      • Brian8506
        • 1666
        Thanks for the help. Got it going. I wasnt there with the other guy today but installing a 2270 print bootrom actually did the trick and made it a lot easier since it had ps printing.
