canon irc 3380i Error E110-000
  • jacky73
    • Mar 2011
    • 8
    dear sir,
    i hv IRC 3380i Error code E110-000,
    i hv try change laser unit already but still got same problem....
    who can help me!!!
    thank sir!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: canon irc 3380i Error E110-000
    Did you check on connection between the laser scanner unit
    and the DC controller PCB, Check on 24V line fuse.
    • teckat
      • 16083
      Originally posted by jacky73
      dear sir,
      who can help me!!!
      thank sir!
      --CHECK the Laser Cable (FM2-9456-000) off the Laser Interface PCB to the DC Controller .
      replace if needed-
      E110-0001= Speed lock of the FG speed control fails to be executed the laser scanner unit 5 sec after the polygon motor starts to operate (Does not reach the specified speed).
      • Rachid.Akli
        • Oct 2011
        • 595
        This model uses two different techniques to control the laser motor speed:
        1- The machine uses a clock signal generated by the laser motor drive PCB to control the laser speed motor.
        2- It also uses the Black BD to control the laser motor speed.
        At power ON, if the laser beam is not generatrd or if it isn't detected, the machine will not show E100 but it displays E110. Then, try to replace the DC controller to.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • teckat
          • 16083
          Rachid.
