IR2200, need help with code E602-0002
  • CCS
    • 266
    I'm mainly a Toshiba tech, I helped a customer out with just a cleaning on their Canon IR2200 a while back but don't know much about the machine. The customer wishes for me to continue to service the machine, so I got a service and parts manual for it.
    Now customer had a power surge and copier came up with code E602-0002.
    The manual says HDD trouble , so my question - what needs to be done ?
    Will HDD need to be replaced and new firmware and such, or can I reset the machine somehow and get it back going ???
    Any help greatly appreciated
  • doktor
    • 214
    Re: IR2200, need help with code E602-0002
    Instructions for you.ir3300-017.pdf
    • CCS
      • 266
      Thankyou
      • teckat
        • 16083
        Originally posted by CCS
        Thankyou
        To ADD on> If available >
        Try this HD CHECK>
        Power off printer hold down the '1' and '9' keys on the keypad >while holding down keys >power up printer with other hand >hold until you see a flashing white block , it will show in the top left corner of the LCD.
        Normally, 'HD-Check' lasts about 15-20 minutes, and ends if no fault is encountered or specific sectors have automatically been repaired bringing up DOWNLOAD MODE on the LCD.
        DO NOT STOP ONCE STARTED.In certain cases,"HD-Check" can take longer than 15-20 minutes and sometimes the machine can hang in this mode and will never complete.
        if this does not work-u need a new HDD
