Can an ir5070 support a 30gb hard drive ??
  • ipvnet70
    • Apr 2012
    • 12
    I am helping out a friend who bought a used ir5070 off an auction. The machine came without a hard drive. A 30gb drive was installed and I'm trying to initialize it but I get this error from the SST:
    Error response:Process has ended in error.
    <<< FileName >>>
    HDDFormatALL:C:\ServTool\iRXXXX\HDFormat\XXxxv0012 \iRXXXX-XXxx0012-HDFormat.ift
    Module : SendFile() - 5
    Is the hard drive too large for the machine ?? Do I need to replace it with a 20gb ??
  • teckat
    • 16083
    Re: Can an ir5070 support a 30gb hard drive ??
    <<< FileName >>>
    u have to first FORMAT the HD using the Canon SST PROGRAM/
    5070 Firmware needs to be loaded in SST>then use the Assist Mode to Format HDD & load rest of Firmware
    it's not the size / that is the issue/
    imageRUNNER 6570/5570/5070
    Canon HDD=WM2-5216-000/ OEM PART
    HTS541020G9AT00/ 20GB
    the HD must be recognized by SST/
    +++ u can not decrypt the .itf file on this model / the .itf file in this model is not visible (encrypted)
    two choices_
    1- do a search>buy a HDD on line=HTS541020G9AT00/ 20GB
    2- buy a OEM Canon one
    on some models the .itf file can be decrypted if visable in folder> see attachment
    • ipvnet70
      • Apr 2012
      • 12
      I can see the *.ift but it is defintely encrypted. I will buy the hard drive and reload with the SST and firmware I have. Just to confirm, the correct hard drive for the SST and firmware I have is a Hitachi TravelStar, 20GB, model HTS541020G9AT00... correct ??
      Thanks for all the help teckat.. next time you're in town, we'll have a round on me !!
      • spectraindo
        • May 2008
        • 313
        Another solution is to clone the hard drive using a clone software, but u have to borrow a hard drive for the source.
        A 30 GB hard drive can be used for iR5070 with cloning.
        20 GB IDE hard drives are difficult to find nowadays.
        • ymmtech
          • Jun 2009
          • 191
          Yap! Can even use a new 160GB HDD with a little bit modify.
          • ipvnet70
            • Apr 2012
            • 12
            The cloning was a great suggestion but I have no access to a working machine to clone. I found the Hitachi hard drive on ebay and ordered it (same make and model teckat mentioned). I already have the SST and firmware so I hope I can finally get this machine up and running.
            • ipvnet70
              • Apr 2012
              • 12
              The hard drive came in but I still have problems. When I installed the hard drive and turned on the copier, the machine would not turn on. If I remove the hard drive, the copier powers on normally. I tested the hard drive and it reads/writes/formats fine with no bad sectors; it seems to be in working condition. Any suggestions ??
              • teckat
                • 16083
                makes no sense-
                u mean the control panel LCD powers up to normal without a HDD & no error code ??
                or u mean printer power ? No control panel backlight or green light. ???
                put in the HD>
                hold down 2 & 8 while powering on the device to enter download mode
                start up SST> go to assist mode to format HD ???>
                then follow prompts to load firmware-
                • spectraindo
                  • May 2008
                  • 313
                  Check the hard Drive connector, insert it carefully aligning the pins, it is easily bent!
                  • ipvnet70
                    • Apr 2012
                    • 12
                    Connector and pins are good. I'm going to work on this machine again today afternoon and double-check.
                    • ipvnet70
                      • Apr 2012
                      • 12
                      I am back with my patient, the ir5070. I installed the hard drive, Hitachi Travelstar HTS541020G9AT00 and flicked the power switch on. The machine starts up and I see the "green" power light come on but the LCD remains off. Also, I can hear the machine sort of "slow-down" and remain quiet. In comparison, if I use a Toshiba MK3021GAS, 30GB hard drive, the machine powers up, the LCD comes on, and I can press the 2-8 combination and connect to the printer via de SST. The problem there is that the SST will not recognize the Toshiba.
                      • teckat
                        • 16083
                        understand this Hitachi is probably a refurb / where did u purchase ??
                        • ipvnet70
                          • Apr 2012
                          • 12
                          Yes, the drive is a refurb... its hard to find this kind of drive new. I am sending out for a replacement just to make sure the problem is not the drive.
                          • spectraindo
                            • May 2008
                            • 313
                            Teckat, it's a iR5070 (5570/6570) not a 5050/5065/5075, hdd size is 20GB.
                            • teckat
                              • 16083
                              Thanks / did not get any sleep/
                              believe u still need FLAT CABLE (FG6-5954-000) to Main pcb from HDD
