I am aware that the error code is regarding the purge unit. Is there any way that I can correct this problem without having to remove or replace the purge unit?
2F1F error code IPF8300
Re: 2F1F error code IPF8300
Carriage Assembly contains bronze bushings which require no lubrication. Customers must be instructed to refrain from lubricating the Carriage Rail, and to clean any dirt, grease, or oil that had accumulated. They should always install the new rail cleaner included with each new Maintenance Cartridge, whenever the Maintenance Cartridge is changed.
Check the print count of the Purge Unit. The Purge Unit must be replaced, when the count reaches 75,000 times. Even before the Purge Unit reaches it's limit, the machine will periodically display a "Replacement Warning Indication". If it goes beyond 71,250 times, then it will go to the Error Code.
At this point the Purge Unit will need to be replaced. Once the Purge Unit has been replaced then clear the count in Service Mode > Select > Initialize > Purge > Initialize (Clear) the number of cleanings.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Service Mode Operation
How to enter the Service mode
Enter service mode according to the following procedure:
1) Turn off the printer power.
2) Turn on the power while pressing the [Load] key and [Navigate] key.
* Keep pressing the above keys until "Initializing" is displayed.
3) "S" appears at the top right of the display.
4) Press the < key or > key to choose the [Set./Adj. Menu] and press the [OK] key.
"SERVICE MODE" appears in the menu list and the MESSAGE LED flashes.
5) Press the ^ key or V key to choose "SERVICE MODE" and press the [OK] key.
* Service mode is added to the [Set./Adj. Menu]. Service mode can be entered even when an error occurs (an error message is displayed) by turning off the power
once and then pressing the above keys.
How to exit the Service mode
Turn off the printer.
READ PDF both pdf's---2F1F _All iPF Models--TP09-1.pdf**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I changed the purge unit on a ipf8300. erreur message (2F1F) deseappeared & message on printer is now "ready", but printer doesn't receive info from the computer anymore. I reset the purge unit counter & tried to reinstalled as a new printer, but again the printer is not recognized by the computer & I cannot reinstall it. (I tried also with different cables & from a different computer. What could be the problem?Comment
