IRC3200N & CLC3200 language problem
  • goldencup
    • Nov 2008
    • 366
    I have an IRC3200N and some CLC3200 which is in german language. I don't have SST and firmware and I know it's not available on net. I have some non working CLC3200 machines, can i get some parts there so that it will be converted to english language? Operation panel maybe? Hope someone can advice me. Thank you very much.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IRC3200N & CLC3200 language problem
    Language is on hard disc with firmware.Did you check about english language option in settings?
    • goldencup
      • Nov 2008
      • 366
      Yes, I did check the settings there is no english language. Can I just get the hard disk from other machine? No more adjustment to be done? If I get the hard disk from other machine, will it affect other operations or functions? Thank you very much.
      • zoraldinho
        • Mar 2008
        • 5015
        Need SST and firmware and 5 minutes of your time.
