ir4570 E000003-0000
  • walidcharifi
    • Feb 2011
    • 379
    ir4570 E000003-0000
    Canon IR4570 Error E000003-0000?
    Unit will not reboot. Can anyone help with what this means?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: ir4570 E000003-0000
    Too low fixing tempetarure!
    Reset the condition in service mode:
    COPIER>FUNCTION>CLEAR>ERR.
    Replace the main thermistor.
    Replace the DC controller PCB.
    • walidcharifi
      • Feb 2011
      • 379
      how to enter in service mode?
      • V-P
        • Apr 2011
        • 679
        *28*
        • walidcharifi
          • Feb 2011
          • 379
          Originally posted by V-P
          *28*
          • arielcanon
            • Mar 2012
            • 106
            press the User Mode key, press the 2 and 8 keys at the same time, press the User Mode key once again.
            please check also heater condition with tester.
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • charm5496
              • 2387
              push the *
              then push the 2&8 at the same time
              then push the * again
              then you are in service mode
              • walidcharifi
                • Feb 2011
                • 379
                Originally posted by charm5496
                push the *
                thank you another error displayE-00000-0001
                • arielcanon
                  • Mar 2012
                  • 106
                  I've face this code E000-0001, then I check the heaters using tester, and found one side is broken..., please check the ceramic heaters.
                  • zoraldinho
                    • Mar 2008
                    • 5012
                    Don't play with fuser.Call a tech!
                    • walidcharifi
                      • Feb 2011
                      • 379
                      thanks
