Canon IR 3045
  • tcypy1961
    • 773
    Canon IR 3045
    Copies made on this copier show streaks that look like poor cleaning from the drum blade; however drum has no residual effects as I've seen from other copiers. Is the problem the drum unit??? Happens whether being copied or printed. What is the black roller in the drum unit??? I cleaned it with alcohol didnot help.
    Thanks!!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Canon IR 3045
    Service manager don't know what is the black roller in the drum unit?.Yes,usually is drum issue.Post a pic please.
    • arielcanon
      • Mar 2012
      • 106
      Re: Canon IR 3045
      If streak lines come from cleaning blade, the streak lines appear along the document.
      If streak come from drum, streak will appear with constant pitch 95 to 95mm
      if streak come from primary roll, streak will appear with constant pitch 5mm
      Learning never ends..
      Never give up, where there is a wheel there is a way..
      • arielcanon
        • Mar 2012
        • 106
        Re: Canon IR 3045
        sorry correction : If streak come from drum, streak will appear with constant pitch 94 to 95mm
        if streak come from primary roll, streak will appear with constant pitch 50mm
        and if streak come from developing cylinder, streak will appear with constant pitch 40mm
