iR2020 Series - Lack of Magenta!! - No error code!
  • Jamesu
    • Mar 2012
    • 101
    Hi all,
    The story on this one:
    We sent a perfectly working and tested machine out, and now it's just randomly stopped printing any magenta with no error code.
    As these are new machines we're not too clever with figuring this problem out right away so could anyone point us in the right direction?
    Thanks,
    James
    Have you tried turning it off and on? No...Oh, it works now!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: iR2020 Series - Lack of Magenta!! - No error code!
    Inspect high voltage drum contact.Replace magenta drum.Check laser shutter.
    • arielcanon
      • Mar 2012
      • 106
      I've faced the same issue and the result was like the picture you uploaded, but the type is IRA C5030, it's funny coz we forgot to conect the connector of laser (M). there is no error issued..., maybe you need to check/re-connect laser connector of M...
      Learning never ends..
      Never give up, where there is a wheel there is a way..
      • arielcanon
        • Mar 2012
        • 106
        Yesterday I got customer complain due to print output was dirty (background of cyan), then I replaced a new drum of cyan, ok. I also replaced drum of magenta due to the same result (background), but after I replaced M drum I got error E020-1160. after check error code, says ensity is still low even the patch level is set to 7 (I thought this code has no relation because I just replaced M drum) 1 in 1160 represent the error for yellow. Re-install old M drum, and problem disappeared..., why this happened? I checked the counter is still below 20K. sorry if this post out of the issue of poster
        • KL568
          _
          • Feb 2011
          • 324
          Originally posted by Jamesu
          Hi all,
          Take a look at the image attached.[ATTACH=CONFIG]15260[/ATTACH]
          Thanks,
          James
          Hi, James
          If the model in question is the Advance 2 series, tried searching Tech Bulletin posted by Teckat. There are modification and firmware upgrade to take note.
          • KL568
            _
            • Feb 2011
            • 324
            Hi, arielcanon
            You ought to raise another post from this, else it could confused a lot the people looking at this.
            Your similar problem for Advance 5030 could be due to coupling gear broken for the affected color. Take out the developer to check for a black cross gear. It should not turn freely. If it is white color meant it has been modify with reinforced material.
            • teckat
              • 16083
              Hi all,
              Thanks,
              James
              imageRUNNER ADVANCE C2020 / C2030 ??????
              First Check the Mylar strip on MAGENTA Laser Shutter
              Mylar strips on the color laser shutters can hang up and block the color lasers. Re-sett the Mylars
              Also check the wire harness for the M laser
              Also check if The laser shutter drive cam lock lever is broken.
              if broken-u need to replace entire Shutter Cam Shaft Assembly/ Cams are NA
              • arielcanon
                • Mar 2012
                • 106
                Originally posted by KL568
                Hi, arielcanon
                else it could confused a lot the people looking at this << if they read carefully, it won't make a confusing..., to solve the issue sometimes we need comparison...,
                Your similar problem for Advance 5030 could be due to coupling gear broken for the affected color << I have already mentioned that this issue was come from forgeting install connector M laser
                • KL568
                  _
                  • Feb 2011
                  • 324
                  Sorry, I did not read carefully. All thanks to my smallish screen
                  Gosh! That is bad R & D / QC from Japanese engineers, it ought to give out an E code for wiring that is not connected.
                  • Rachid.Akli
                    • Oct 2011
                    • 595
                    Hi
                    I suggest you stop the printing cycle by opening any door. Then, have a look on the image on the CTI and the magenta drum. According to the result you can conclude:
                    1- If there is no image on the Magenta drum: The drum is not turning or the laser beam doesen't reach the drum.
                    2- If there is an image on the drum and not on ITB: Default of the magenta primary transfer.
                    If you've a new drum, replace it to get better idea.
                    Rachid.
                    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                    • Rachid.Akli
                      • Oct 2011
                      • 595
                      Hello James
                      Sorry, i used the french word for ITB.
                      CTI = ITB
                      Rachid.
                      • Jamesu
                        • Mar 2012
                        • 101
                        Problem solved.
                        Took laser assy out and reseated it. Copier now works fine!
                        Probably a loose connection.
                        • Jamesu
                          • Mar 2012
                          • 101
                          Been keeping an eye on this all day, but after it printed fine it went back to printing no Magenta.
                          So i tried all connections and stuff again with no luck, ended up swapping the laser assy from a brand new machine and been monitoring it and its working perfectly fine.
                          The problem must be to do with the laser assy then, but as its still under canon warranty i'm getting it swapped!
