Can i set as the default double clicks for ledger, and if so where in service mode do i make the change. Thanks.
Ir c 3200, 3220 and ir c5185 double count
Re: Ir c 3200, 3220 and ir c5185 double count
in service mode
COPIER>OPTION<USER>
choose COUNTER 2 and change the value to 102/ hit Ok !-
Turn off / on copier.
COUNTER 2
Used to change the counter type display for the operation panel’s software
counter 2, to meet user or dealer requirements.
NOTE:
This adjustment can be performed using Counter 2, Counter 3, Counter 4,Counter 5 or Counter 6.
Counter 1 can not be changed because this is reserved for "total" copies.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
