Canon IR 3570 phantom jam
  • callmefirst
    • Feb 2012
    • 51
    I have a Canon Ir 3570 that say open right door and remove jam. There is no paper present and the sensors are clean and sound. Has anyone seen this problem, thanks
    • 16083
    Re: Canon IR 3570 phantom jam
    is there a JAM CODE in service mode ?
    • Oze
      Ricoh Fanboy
      • 1663
      Check the registration flag sensor.
      If the flag is worn it shortens the length and get's hooked up on the frame.
      Even worse if it's got one of those metal clips on them....the clip opens and catches the frame and it holds the sensor in the up position.
      Go into I.O. mode and check for an open sensor.
      • arielcanon
        • Mar 2012
        • 106
        check the lates Jam code (No.1) on service mode, click on Jam Code to see related sensor that may cause Jam (SensorNo = PSxx), then Check on I/O sensor to see whether that related sensor (PSxx) working or not (ON/OFF).
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • kstan268
          • Apr 2012
          • 85
          I face this kind of problem before,,You can try the sensor that located inside the transfer roller ass'y is a duplex sensor!!hope will help u
