scanning cheques
  • roho
    • Mar 2009
    • 844
    [Misc] scanning cheques
    i have a cust who is using the adf for cheques scanning. the scanner never scans the entire cheque. the model in question is a ir 3080, though I've tested other models, same result. Is there s service mode setting or user setting that can make the scanner/ dadf scan an entire cheque. The size is 8 1/2 x 5. Thanks!
  • JustManuals
    • Jan 2006
    • 9838
    Re: scanning cheques
    Just curious, why are you scanning checks?
    • vigour
      • Aug 2010
      • 1038
      hope you are loading them in the R direction (like a Legal sheet).
      An Ir 600 customer would cheat the feeder by opening the guides to Letter size and put a box of staples against one edge,to keep the documents straight.
      3080 should be centre feed, so there should be no problem closing the guides to STMTR and feed correctly.
      • spectraindo
        • May 2008
        • 313
        Yes ,you have to cheat the ADF for the irregular size of the cheques.
        Put the ADF guide to STMTR (8,5 X 5,5 ) and put an 0,5" thick book on the side to keep it straight.
