IR-C3220 won't to Scan to Folder.
  • THINKINK01
    • Mar 2009
    • 31
    I got such a great response on the last question that I decided to test my luck again.
    What is required to Scan to Folder? Is an Universal Send Kit necessary, and if so how do I go about obtaining one?
    The machine has the ImagePass 2 installed currently, is the Universal Send a separate item?
    Thank you for your input.
  • copymech
    • Sep 2011
    • 196
    You need the scan kit. It is a nic and a resolution switching board.
    • THINKINK01
      • Mar 2009
      • 31
      Re: IR-C3220 won't to Scan to Folder.
      Thanks.
      Any idea of how we may be able to obtain this kit for a resonable price. Most of the pricing we've seen was in the $1.1K area and that is 2x more then what we paid for the machine.
      • vigour
        • Aug 2010
        • 1038
        If you have a Send Tab on your control panel, you are in luck.
        • arielcanon
          • Mar 2012
          • 106
          you need USEND kit (lecense key), enter lecense key in system setting > license registration
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • teckat
            • 16083
            Send function is available only if the optional-
            Color Universal Send Kit
            & Resolution Switching Board are installed.
            To identify if the Resolution Switching Board is installed, and installed correctly, first look at the board slot covers on the cage unit at the back of the imagerunner. The Resolution Switching Board is NOT installed if the second Metal cover from the bottom has two bumps (nipples) diagonally across from each other. If the plate surface is flat, the board is installed.
