CANON IMAGERUNNER 2020 - Can't print USB or Network
  • screwdriver08
    • Jul 2010
    • 160
    It's me again with yet another problem. Canon Imagerunner can't print directly using USB and/or Network. I am not an expert in connecting printers by network but I do know how to connect it straight to a computer. I did (with the installation CD)..the driver was installed and everything but it still would not print. This has been used as a Network Printer but now it does not work..not even directly through USB. I think it was after we changed the FUSER UNIT when the problem started. If anyone could help I would really appreciate it.
  • arielcanon
    • Mar 2012
    • 106
    Re: CANON IMAGERUNNER 2020 - Can't print USB or Network
    you can check the IP address setting from your PC and copier (use manual setting IP address), make sure that it's correct eg: PC 192.168.1.20 subnet:255.255.255.0 and copier : 192.168.1.21 and subnet 255.255.255.0 then test ping via cmd... ping 192.168.1.21 -t if ok, you can continue to re-install driver. please avoid IP address like this 192.168.0.20, coz can also make a problem. there is no relation between changing fuser unit and printing error
    Learning never ends..
    Never give up, where there is a wheel there is a way..
    • screwdriver08
      • Jul 2010
      • 160
      Thanks, I did check the IP address and they are the same...computer and copier. That is the thing I have been trying to explain to them, but they think that because of me changing the fuser, the Network printing does not work.
      • screwdriver08
        • Jul 2010
        • 160
        Oh, and the other interesting thing is that it does not even print directly using USB-computer connected directly to printer.
        • Blues Guy
          • Aug 2009
          • 216
          Is that you have install PCL5e driver version ?
          Try delete it and install UFR II driver version.
          • montana
            • Aug 2008
            • 392
            yes blues guy is wright...install the UFRII printer driver instead of pcl5....
            • northernlife
              • Sep 2011
              • 847
              If that doesn't work, clear all. Had this same issue on a 2200 that mmi clear fixed last week but the 2020 doesn't have MMI clear.
              • screwdriver08
                • Jul 2010
                • 160
                Ok, how do I get to choose between the PCL5e and UFRII version?
                Also, it that does not work how do I clear all?...WOW, I need a manual and a Tech with me.
