white lines on ImageRUNNER ADV C5030i
  • seniortech
    • Dec 2007
    • 180
    I have a problem with sharp white bands in yellow (in feed direction) on a C5030i and it appears to be caused by dirt/contamination in the laser path. C/M and K are also showing bands (seen on on PG5 test page) I have tried cleaning the dust blocking glass (using the tool) with no success. looking further when removing the process carriage and ITB unit there is a lot of dust/toner an top of the laser units.
    Apart from the dust blocking glass cleaning tool is there another way (hopefully easy) of cleaning out the laser path/laser.
    Many thanks
  • canonclc
    • 71
    Re: white lines on ImageRUNNER ADV C5030i
    Pull the draw out and lift up the shutters by hand and clean them with a cloth Takes 2 minutes .
    • seniortech
      • Dec 2007
      • 180
      Thanks Canonclc
