Any get a code like this? E064-003. The manual says rep DC controller and High Voltage Power Supply. Just wondering if there is anything else to check before I end up ordering these parts. Thanks
E064-003 on a Canon IR3570.
Tags: None
Re: E064-003 on a Canon IR3570.
Maybe get solid black ore blank prints?
-Check HVT
- Check if Toner gets on the Developing Bias Tab
-Replace the drum
- check the drum contacts
-Try to clear DC-controller (p-print)If it ain't broke, don't fix it
A picture is worth a thousand words -
It's intermittent. Sometimes I can get 100 or so copies out then it errors out. Copies look great. I will replace the drum and check all those things you mentioned. ThanksComment
I have the same problem e064-0003 with black copier and again it is intermittent works fine when we are here the black copies look like they have the image mixed in with it drum isn't that old and we have checked the contacts of the drum and dev.Comment
The E064 code with a 0003 sub code can occur if Toner gets on the Developing Bias Tab. If the Toner is getting on the Developing Bias Tab you should check the seal on top of the Developer.
Capture.PNGComment
Check papper(humidity). And transfer roller , just heat it with a drier and chek.......
Sent from my HTC Desire X dual sim using TapatalkComment
