How do i reset dcon on a c5185
  • crwoo
    • 76
    Hi, i have a canon c5185 that in the last 2 years it happened twice where the colors would be offset by about .1" each color, and both times a tech came out and took belt off and cleaned it. both times it didn't help and they did a dcon reset.
    well same thing happened again, and i want to know what the steps are for the reset. tech printed a few sheets, did reset, then entered values back in. can anyone let me know what the steps are? thanks!
  • totoro
    • 568
    Re: How do i reset dcon on a c5185
    From what you said, it sounds like you are not a Canon tech. Doing a DC con clear can cause you more problems that it's worth if you don't know what you're doing. Do yourself a favor and call a tech in and let them do it.
    Totoro
    • crwoo
      • 76
      thats what i would normally do, but tech is 3 hours from here, last time it took him 5 minutes. if i had instructions i could do it myself.
      • Rachid.Akli
        • Oct 2011
        • 595
        You're also paying for the time spent to get the knowledge alowing to do the job the right way in 5 mn.
        rachid
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • crwoo
          • 76
          rachid
          i know, i know.
          but will anyone please answer my question...please!
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Bad idea.
            • crwoo
              • 76
              Originally posted by zoraldinho
              Bad idea.
              i know its a bad idea. its also a bad idea to take the money i saved an buy myself a 5d mark 2. so what. how do i do it is what i am trying to find out. i know how to reset. but i need to know how to print the parameters and type them back in.
              • vigour
                • Aug 2010
                • 1038
                you need a new belt by now
                • KL568
                  _
                  • Feb 2011
                  • 324
                  Just think about it:
                  Tech spend 3 hours drive to your site and do less than 30 min job. He is maybe paid a couple hundred or less???? After that, the machine works and you earn from printouts from it till the next servicing require
                  Now if somebody were to show you the steps for it. You can starts your printouts from the supposedly working machine. A few weeks later, that "bad idea" will crept back in another way to wack the machine out so much that the actual tech travel 3 hour and spend hours to unravel that "bad idea" (cleaning up ; replaced damage parts). In the meantime , you can't do any printouts at all.
                  Take the advise. Call tech in and ask him nicely of he is willing to impart this adjustment skills to you. He is the on-site tech that knows your machine better than this forum contributions. Make it a win-win situation for both of you all(tech no need drive 3 hours while you gets to have your printouts)
                  Actually, offset by .1 in duration of twice in 2 years meant that tech is extremely skilful and your machine well-kept. I had seen machine offset by much more than .1 AND after doing the required cleaning up and adjustment, it call back next day.
