Canon IR-3320 Stretches doc's with DADF-B1 feeder.
  • aosman
    • Jul 2025
    [Misc] Canon IR-3320 Stretches doc's with DADF-B1 feeder.
    Client uses as scanner and when scanning larger documents, you will sometimes hear a skipping/ slipping noise, this will result in the image being shifted on the scanned page. You will see the left part of the doc. starting in the middle of the page. Same if it were a copy. I have replaced all feed parts, feeder drive motor and belt. I have calibrated for stop position. After changing the drive motor, the unit did not act up for two months. Any tips would be great. Thanks in advance.
  • vigour
    • Aug 2010
    • 1038
    Re: Canon IR-3320 Stretches doc's with DADF-B1 feeder.
    Originally posted by aosman
    , you will sometimes hear a skipping/ slipping noise, this will result in the image being shifted on the scanned page. You will see the left part of the doc. starting in the middle of the page. Thanks in advance.
    REplace your scanner motor
    • aosman
      Thank you. I will check out the feed unit. Is it the Same for the K1 and the B1? Could the problem also be with the scanner rails not being lubricated? I love the newer system of scanning from the feeder, much easier to diagnose.
