iR Advanced 6055 - Finisher FN-E1 - Error E540 - 8002
  • MFPTech
    • 486
    The first sheet is half way out on the Finisher top tray and the second sheet stops under the punch unit.
    After some troubleshooting it looks like I have to replace the Main Finisher board.
    Anyone has had this before please?
    Thanks in advance!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: iR Advanced 6055 - Finisher FN-E1 - Error E540 - 8002
    E540-8002.pdf
    • MFPTech
      • 486
      Originally posted by zoraldinho
      [ATTACH]15764[/ATTACH]
      Thanks for the info. Will order the new style sensing flag and will let you know. It kinda makes sense because the problem started as intermittent and became consistent.
      Cheers,
      • rincoh
        • Feb 2018
        • 2
        Thanks in advance!
        There are simple to solve this problem.
        You just need used 3M double side tape to paste the
        Receiving tray plated at sensor flat position..total place
        Is 4..Try this
