Canon C5185 Code NG (#801) please
  • dqtek
    • Sep 2010
    • 16
    [Error Code] Canon C5185 Code NG (#801) please
    Im getting code 801 scanning, customer's network automatic changes passwords for there users computer, would this cause problem.
  • vigour
    • Aug 2010
    • 1038
    Re: Canon C5185 Code NG (#801) please
    yes
    you need the proper authentication
    • dqtek
      • Sep 2010
      • 16
      Where would I find the proper authentication. In the smb setup. Thanks for getting back to me
      • vigour
        • Aug 2010
        • 1038
        I can't give you a good route, because i am doing it from memory, and I have not done it in a long while.
        Basically setup a new entry, or edit the old one by going to
        address book
        create new address
        select file from the dropdown menu ( you will see email,fax as other choices)
        then at some point you browse the network, drill down until you get to the shared folder you need and it will ask you for username and password.
        have the customer put that in.
        First you have to know where the shared folder is, to be able to drill to it.
        Finding editing is tricky if I remember correctly.
        I think it is somewhere along the path to create a new entry.
        • dqtek
          • Sep 2010
          • 16
          address book
          create new address
          Thanks I will check that out.
