hello guys, can you help me and ask some advice about my problem of canon ir 6000 the tray 1 was not lifting or working, this machine is slight new only 1000 copies it made, maybe before theres a technician repair this machine because when i check up the first feeding unit theres a broken part of it thats why i try to change the first feeding unit and dosent work then i try to change the lifter motor same problem, i try to check the harness or wires if theres a connections or continuity all are okie, so i try to change the motor driving board it was located at the left side down part of the back of the machine still no luck same problem so i decided to change the controll board then after that still got the problem no luck at all..so pls guys if you have been already encounter that same problem can you share some solution that you made..all your help would be appriciated guys.. i will wait for all your reply.. godbless ang thanks in advance...
canon ir 6000 tray 1 not lifting or working
Re: canon ir 6000 tray 1 not lifting or working
remielee,
This happen to me once, where tray one the right hand deck would not lift.
I found that the front cover was miss adjusted and would not allow the
tray to be pushed in all the way, and it was only miss adjusted by .25 inches.
Try this, take the front cover off the tray and push it in. With all you've done
I can not imagine there could be anything else wrong, plus it is a low meter count.
You should have a book for this model. The feed heads for tray 3 and 4 are the
same and can be switched. The feed head for tray 1 is different and so is the
feed head for tray 2.
Leave a post on the service manual request page. I am sure you should be able
to get the manuals. They will help a lot.
DR -
would u mind to upload the broken part...., (or give us part number)Learning never ends..
Never give up, where there is a wheel there is a way..
Did you try what I mentioned in my last post?
You may not have a broken part, it may just need to be adjusted.
That is why I mentioned taking the front cover for tray 1 off.
If it is not put on correctly it can cause this problem.
Try it. It only takes a few minutes.
DRComment
DRComment
Originally posted by Canon.TechHow can you have a new ir6000 with only 1000 prints!? this is a 10 year old model!?????
i know sir that this machine was an old models of digital machine for a canon. i said on my previous post that was slightly new because i base only on its meter count or meter reading, i know that this machine can take more copies and heavy duty machines since of its drum life can take 3 millions because of its silicon drum type, the costumer did not use it for a long time. i was here at ksa they are still using it and some companies here still selling this kind of models it means it was still on the market here i dont know about in other country since it was an old models of canon.Comment
im sorry sir i already change it and the broken feeding unit was already given to the warehouse i cannot be able to take i back again. thnks for the reply sir.Comment
So remielee,
All I was saying is take the front cover off and push the tray back in and see if it
lifts the paper.
It sounds like you replaced the whole tray 1 unit?
Did it fix the problem?
DRComment
