about COPIER CANON IR 2018
  • raztech
    • Dec 2008
    • 88
    Good afternoon all of you...
    Ihave installed a new network card for my canon copier ir 2018....
    The desk top read succefuly the adress ip...
    but it is strong ...I didn't success to print...
    would you like to help me....please..
    thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: about COPIER CANON IR 2018
    Install UFR driver.
    Can you ping?
    RUI?
    • songela
      • Mar 2008
      • 216
      This model is network ready, why do you have to install a network card?
      You just need to choose the UFRII driver.
      Regards!
      • raztech
        • Dec 2008
        • 88
        Thanks...but i did ,what did you suggest....unfortunately..no results...
        IF You have something like notice or book...forwaed it ..please..
        GOOD LUCK
        • arielcanon
          • Mar 2012
          • 106
          iR 2018 it network ready. You need to setup connection, test connection using ping command then setting IP address. [SYSTEM SETTINGS] > [NETWORK SETTINGS] > [TCP/IP SETTINGS]. Finally install UFRII printer driver.
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • DAG COPIERS & COMPUTERS
            • Oct 2010
            • 860
            This model comes network ready. You need to install the driver. You may download both the iR NETWORK GUIDE MANUAL and the UFRII DRIVER from CANON EUROPE WEBSITE-software downloads. Just Google it and get down to business. You may use an Ethernet cross-over cable, or straight cable with a HUB for your connection.
