Canoan IR105 printing slower than copying
  • thector
    • Aug 2025
    [Misc] Canoan IR105 printing slower than copying
    I got a 3rd Canon IR105 (used) and this machine is printing slower that my other 2. Same pdf same M3 Fiery (settings are virtually identicle) and when copying it goes at rated 105 pages BUT when printing it slows down to about 80. Physically I can hear that the paper being pulled from Drawer 1 is not constant - it pauses for about 2 seconds after every 5 to 7 pages. You wouldn't know that unless you got down by the drawer and listened. VERY FRUSTRATING! And I even tried my other M3 Fiery on that machine and it still happens. I even put on a different K3 fFinisher from my other machine, same problem. That is why I think it has to be some setting in Service Mode or something. PLEASE HELP!
  • vigour
    • Aug 2010
    • 1038
    Re: Canoan IR105 printing slower than copying
    how about speed from drawers 2,3 and 4.
    maybe you need new rollers.
    it might be slowing to allow proper separation. or pickup
    • thector
      It has new tires and that wouldn't matter since copying from same drawer doesn't slow down.
      • KL568
        _
        • Feb 2011
        • 324
        There is 2 options for you
        Either
        Do the tedious way of P-print of both iR105 and compare difference.
        OR
        Easy way out is CLEAR MMI and reboot it. Remember to set back service mode of M3
        • thector
          Oh man, not good. I did Option 2 and now my M3 Fiery says "Connect Imiage Runner" when rebooting machine and Fiery. It's like they arn't talking anymore! Maybe it's because I doidn't know what you meant by "set back service mode" of the M3. (Also I didn't do option 1 because I didn't understand that one). PLEASE HELP me get back up and running.
          • thector
            DIREGARD MY PREVIOUS POST, I figured it out. I fond on another post how to reconnect a Firery by changing INT-CNT to "0" then reboost then put to "4" and it was able to re establish connection. AND it is now running at full speed!!! Probably due to your advice of clearing MMI. THANKS I'm so happy
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5018
              There comes a time when the mind takes a higher plane of knowledge but can never prove how it got there.
              • KL568
                _
                • Feb 2011
                • 324
                That is great!
                Try to do a P-print of the copier. It a 10-20 pages printout of copier's internal factory adjusted settings, each copier are different. Keep it as a backup, just in case do another type of CLEAR will reset a few other more important settings.
                Have a good weekend
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Is your machine at its latest system version? If not upgrade it.
                  Rachid
                  "Find a job you love and you’ll never have to work a day in your life." Nagy's father
