There is an error code E000014-000 on 5065. fixing motor error or phase lock signal.
Im pretty sure it is the fixing motor but if i remove the actuall motor from the fixing unit and turn it on, it runs fine. I was hoping for a little bit of feed back with the issue.
ive already swapped out the fuser unit with a new rebuild.
could it be one of the fixing sensors? has anybody had an issue similar to this before, ive been told that fixing motors dont fail very often?
I also have a 5185 machine with the error code E000007-0211
is the only way to trouble shoot this is to take meter reads off of the fixing belt displacement control motor and the pressure belt displacement control motor? there are eight fixing sensors in this case... should i go through and check them all with meter reads as well?
My TRG reccomends just replacing the fixing unit (kind of what i would rather do) but my service coordinator has told me it is two thounsand dollar part for this machine.
i had someone help me pull out the unit and check the termo fuse and clean up the sensors but still the same error code.
any body have any experience with this error code in the past?
thanks heaps!
and happy mothers day!
thanks heaps!
