Error e740-003 on canon ir3300
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Hi to everybody. I have this machine which was originally in spanish using the network,card to print from the PC.When i changed the language to English running,a system firmware,thru the sst,the machine shows the above error.However if you remove the network card the machine works normally and can print thru the parallel cable.The client wants to use the network cable to print,where could the problem be? Thanks in advance.
  • vigour
    • Aug 2010
    • 1038
    Re: Error e740-003 on canon ir3300
    If your machine has the new ethernet board FG6-9898
    you need system software v41.01 and boot rom 23.40, or newer
    newest ethernet FM1-0196 needs v42.03
      • Aug 2011
      • 279
      Thanks Vigour,i will try it out when i get back to the machine.
