Di5510 job will not stay in qual in command workstation
  • worm
    • Nov 2011
    • 36
    [Misc] Di5510 job will not stay in qual in command workstation
    every time i run a job it will jump out of the Qual in workstation is there a setting in the copier to fix this
  • TheOwl
    • Nov 2008
    • 1732
    Re: Di5510 job will not stay in qual in command workstation
    Jobs should come out of the queue when printing to any device, but the Fiery Controllers have a printed job queue.
    If this is what you are talking about, then you must make sure that the Fiery is set up to save jobs in the printed queue after printing a job. Factory default for this is 10 jobs which will then show up in Command Workstation.
    If you are trying to send print jobs and have the Fiery Hold them without printing them, then you will need to setup the driver so that the TCP/IP Port uses LPR and then use the queue name of HOLD so that jobs are spooled, but not printed.
    • teckat
      • 16083
      this is a Canon forum> post your issue in the Konica forum
