Canon C5870 6800 copy quality
  • gideon
    • 276
    Drops black toner on page, small black spots and such, even when copy on single color cyan magenta or yellow still drops black spots.
    I have only one of those copier in my neck of the wood, any idea for the specific part I need to replace to solve this problem? I assume it is in the black unit.
  • teckat
    • 16092
    Re: Canon C5870 6800 copy quality
    First check mylar for damage or worn areas in the ITB Cleaning Assembly ( Transfer Cleaner Assembly ). There is no part number assigned to the mylar, therefore the ITB Cleaning Assembly must be replaced.
    ITB ( Transfer Cleaner Assembly ) PN: FM2-0522-000
    Replaced the primary filters (FL2-0554-010 and FL2-0429-000) and the primary corona assembly (FM2-0429-000).
