Information sharing about crossover and direct cables.
  • Rachid.Akli
    • Oct 2011
    • 595
    Hi all of you
    I would like to share the following information with all copytechnet readers:
    1- With Windows XP, it is possible to use a crossover and a direct cable in a singgle network connection( a two machine network).
    2- With Windows 7, a crossover is the only possibility. The direct cable will not work in a two machine network.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • Hansoon
    • Sep 2007
    • 3379
    Re: Information sharing about crossover and direct cables.
    I think this will not depend so much on the operating system being used but on the NIC's/Mainboards.....
    Hans
    • DAG COPIERS & COMPUTERS
      • Oct 2010
      • 860
      Did you try to connect the two devices through a HUB or Switch when using the direct (straight) cable?
      I think it should be able to work. Haven't tried it myself with Wins7.
      • RRodgers
        • Jun 2009
        • 1947
        It also depends on the hub or switch as well as the Nic's/mainboard (mentioned above) Some switches will auto sense and correct if need be.
        But if you wanna go from PC (or laptop) straight to copier I always use a crossover.
        • TheOwl
          • Nov 2008
          • 1732
          I have been using HP laptops now for the last 6 years and I no longer carry a crossover cable as my laptops have always auto sensed the TX \ RX lines correctly.
          This goes for using both Windows XP and Windows 7 with both 32 and 64Bit versions.
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            Owl is correct. Newer high end nic cards auto sense the need for a crossover/direct connection. Some cheaper nics do not have this feature. The windows version is irrelevant here as it is the hardware itself that does the auto sensing.
