E748-2024
  • phil crozier
    • Jul 2025
    [Error Code] E748-2024
    I have E748-2024 on an iRAC 5051. I have changed all memery chips, but no luck. Any help would be greatfully accepted.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: E748-2024
    You are not change all at the same time i believe!Also main conroller 2 can be bad.Use a self diagnostic program.Read PDF..
    gen-850.pdf
    • teckat
      • 16083
      Re: E748-2024
      Remove & re-seat Main Controller 1 and Main Controller 2 to the Riser PCB.
      • phil crozier
        Re: E748-2024
        Hey Guys, thanks for your help. Just a quick update now the machine is working. It turned out to be the Main Controller 1.
        • zoraldinho
          • Mar 2008
          • 5007
          Re: E748-2024
