E 000804-0001 in IR 6570
  • bluesky2000
    • 95
    Hi.........
    my device have the E 000804-0001 in IR 6570 ?
    help please
    Can some one show me in image where the ERROR !
  • wild boy
    • Oct 2010
    • 2
    Re: E 000804-0001 in IR 6570
    CHeck IH POWER SUPLLY
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      http://www.copytechnet.com/forums/ca...highlight=e804
      • Alex ahir
        • May 2012
        • 125
        check HP sensor, some time fuser sutter and fuser roller is not setting properly and give that error
        • Alex ahir
          • May 2012
          • 125
          sorry i thaught its 840-001, for 804-001 check fuser powersupply fan, its located on left side of the copier and undernith the scanner.
          • bluesky2000
            • 95
            thanks all for help
            can u show me in image please
            • zoraldinho
              • Mar 2008
              • 5013
              Originally posted by bluesky2000
              thanks all for help
              Did you check posted link?
              • bluesky2000
                • 95
                yes i check it
                it's not work with me the solution
                i want to check another solution
                thanks for help..
                • vigour
                  • Aug 2010
                  • 1038
                  did you find the IH Power supply fan?
                  Either the fan is bad or the dc controller.
                  Take the finisher off
                  Take the left side panels off.
                  change the fan
                  Turn on and look if the fan turns.
                  • bluesky2000
                    • 95
                    change the fan
                    I have changed the fan
                    But when i run the device and I see the fan still does not work
                    and still the ERROR 000804-0001
                    • vigour
                      • Aug 2010
                      • 1038
                      replace whatevr tells the fan to turn on ----dc controller
                      • bluesky2000
                        • 95
                        whst did you mean
                        • sqrt
                          check mosfet IH
                          or fuse Dc controller and clear Error
