ir 7086 saddle finisher v2 problem
  • nasertop
    • Aug 2011
    • 40
    Hai Friends,
    one of my customer used ir 7086 copier without finisher, as i tried to connect with new saddle V2 finisher, I cant able to enable the finisher through service mode in OPTION, ACC PST-D, because in that particular screen, i was not able to apply the settings & it was showing as i mentioned below,
    ACC1 _ _ _ _ _ _ _ _ _ _ (_ _). (there is no numbers)
    so please guide me to get default screen to enable the finisher.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: ir 7086 saddle finisher v2 problem
    Turn on the finisher and then the host machine in
    the order indicated.
    Start service mode, and specify the order of connection:
    Read PDF......saddle_finisher-v2-ip.pdf
    • nasertop
      • Aug 2011
      • 40
      thank you friend .i will follow this . but i have a doubt. i am going to install only V2 SADLE FINISHER. for that, is the T connector nessery or not . because ihave no T CONNECTOR. with out T CONNECTOR FINISHER will be work or not.
      • spectraindo
        • May 2008
        • 313
        You must use T CONNECTOR for ARCNET Cable from Machine to Finisher, do not forget the terminator plug.
        • teckat
          • 16083
          When connecting the imageRUNNER 7105 / 7095 / 7086 Series main engine to its delivery accessories (ex. Finisher V1 / Saddle Finisher V2), the Signal Cable, T-Shape Connector and Terminator must be configured correctly.
          If an improper connection is made (ex: connecting the signal cable directly to the main body without attaching it to the T-Shape connector or forgetting to attach the terminator to the end of the T-Shape connector), the following error codes can occur:
          E500: Finisher Communication Fault.
          E711: Communication error has occurred between the Main Engine and its Delivery Accessories.
          READ PDF's--
          iR7105_7095_7086_All-ARCNET Connections--TP06.pdf
          Finisher V1_Saddle Finisher V2--INSTALL.pdf
          • nasertop
            • Aug 2011
            • 40
            i connect T connector now the finisher start working. thanks for your advice .
            • zoraldinho
              • Mar 2008
              • 5007
