HD
  • Dzeak21
    • Oct 2007
    • 43
    HD
    I have a couple Advance series machines and was wondering if there is a print out like on the xerox that tells you that hd has been erased.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: HD
    You can't make print with erased DIsc!What exactly you try to do?
    • Dzeak21
      • Oct 2007
      • 43
      Re: HD
      On the xerox machines they will give you a print out that the HD has been overwritten I was wondering if the Advance series machines had any paperwork that shows that the information has been deleted from machine. I have done the HD Clear, in the service mode but is that it.
      • zoraldinho
        • Mar 2008
        • 5018
        Re: HD
        Advance model please?
        HD-CLEAR is for Initialization of specified partition.(COPIER> FUNCTION> SYSTEM> CHK-TYPE)
        I believe you won't to upgrade firmware.Use service support tool!
