Canon ir 6000 driver problem:
  • ybnews
    • Oct 2008
    • 94
    I just got a new computer. Moved up from a Windows XP Pro to Windows 7.
    Was using Canon IR 5000-6000 PCL6 drivers in the Windows XP system.
    Windows 7 software is not allowing saddle stitching in the booklet mode.
    Any suggestions on what software/drivers to try for Windows 7?
    Thanks for your attention.
    Dana Lewis
  • vigour
    • Aug 2010
    • 1038
    Re: Canon ir 6000 driver problem:
    if you have not loaded the latest driver from canon website , do so now.
    try pcl 5e, most of us prefer to work with that.
    if you do have the latest driver.
    activate ,get device status from your driver
    the new drivers are setup differently, especially for booklet, you may have to poke around and experiment.
    you can also print letter size single sided to the mailbox
    then select your document and change print settings to make booklets.
