irc2880
  • jose dai
    • Dec 2008
    • 25
    irc2880
    replace drums massage even changing and initialize. help
  • teckat
    • 16083
    Re: irc2880
    Suspect a connection to the ITB unit.
    or-------------------------------
    If only one drum was replaced, try reinstalling the original drum. If the message clears the new drum is bad and you must order another drum.
    If all drums were replaced, reinstall the original drums. If the message clears, reinstall the new drums one at a time. When the 'Replace Drum' Message returns, the last drum you reinstalled should be replaced with a new one.
    Do not replace drum units with new ones unnecessarily, in order to check function operations during service, etc. The device blows the drum fuse as soon as it detects a new drum unit and resets the drum life counter to 0. Even if the old drum is replaced immediately, the drum life counter will increment as a new drum unit.
    In Service Mode COPIER>FUNCTION>INSTALL >AINR-OFF invalidates drum initialization that is performed when a new drum unit is installed. Also, the fuse is not blown, as it would usually be after drum initialization is complete.
    This mode would be used to replace a drum unit temporarily in order to check image quality, for example trying to trace the cause of the problem.
    0: Initialization carried out for new unit. Fuse blown (Default)
    1.: No initialization for new unit. Fuse not blown.
    Further, this service mode should be set to [1] only when necessary for service. After the service is complete the setting must always be returned to [0].
    • Herrmann
      • Jan 2006
      • 792
      Re: irc2880
      If you have a bad color registration in addition, you should have a look at the ITB drive gear also. If it is broken, the friction between the drums and the itb is great enough to drive the itb, but drum initialation will fail.
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • jrgf67
        • Feb 2010
        • 37
        Re: irc2880
        Greetings.My Englis his very poor.From what you say to me has happened and what I missis to update the system and the DCON to the latest version.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          Re: irc2880
          To prevent the symptom abovementioned, upgrade Dcon to v61.01 or later.Read PDF...irc3380-034.pdf
          • teckat
            • 16083
            Re: irc2880
            good >very good> that's GOLD
            • zoraldinho
              • Mar 2008
              • 5018
              Re: irc2880
              7777 posts! Today is your lucky day!
              • jose dai
                • Dec 2008
                • 25
                Re: irc2880
                Originally posted by zoraldinho
                To prevent the symptom abovementioned, upgrade Dcon to v61.01 or later.Read PDF...[ATTACH]15971[/ATTACH]
                upgrade firmware done . problem solved thanks
                • jose dai
                  • Dec 2008
                  • 25
                  Re: irc2880
                  [ATTACH=CONFIG]15967[/ATTACH]
                  [ATTACH=CONFIG]15968[/ATTACH]
                  thanks a lot
                  • zoraldinho
                    • Mar 2008
                    • 5018
                    Re: irc2880
