Canon IR2525 can not network scan.
  • computersupportguy
    • Jul 2025
    I have a canon ir2525 that was setup to scan to the network. It worked fine for a while and then I came in one morning and it wouldn't work. After sending to the network the job would wait and then eventually an error message would be printed. I do not currently have an error code because someone threw the paper away. We had a technician come out and check it out. All of our settings were correct, the user for the address book had admin rights, correct password, used the actual IP address as the target. He reloaded the firmware on the machine and it still didn't help. Think anyone could give me a hand? Thanks in advance guys
    PS. I did a work around for now for it to be sent to and FTP server.
  • KL568
    _
    • Feb 2011
    • 324
    Re: Canon IR2525 can not network scan.
    Hi,
    From the iR2525, were you able to "Browse" the network for any PC & properly login? If cant, is the "SMB" of iR2525 set to "OFF"
    • copymech
      • Sep 2011
      • 196
      The IP address of the host computer may have changed. Try using the host name in place of the ip address.
        Originally posted by KL568
        Hi,
        When we browsed the network we were able to log in. SMB is set to on, and we also have LM announce set to ON.
          Tried using the host name as well. The IP address is static, if that helps.
          • mramlawi
            • Jul 2011
            • 838
            HEllo try to download the latest driver also make sure that there connection between the pc and the copier use the ping utility
            Regards
            Waiting for ur reply
            Distinguished road makes you jewel in rough
            • teckat
              • 16083
              READ--
              iR2545i Series--Systems Settings Guide Part_1.pdf
              iR2545i Series--Systems Settings Guide Part_2.pdf
                Regards
                Drivers have been downloaded and installed but still no avail. Both are able to ping each other.
                  Originally posted by teckat
                  READ--
                  [ATTACH]15981[/ATTACH]
                  [ATTACH]15982[/ATTACH]
                  Thanks for the documents. The copier is set up correctly. The network administrator, certified tech and myself have already went through these.
                  The technician was supposed to call back after he found a fix for the problem, but that has been a few weeks ago.
                  • kronical
                    Kronic Copier Ninja
                    • Nov 2009
                    • 230
                    I have seen this before and hopefully this will help. Same thing was working on initial install then stopped working. Solution was to configure the machine via dhcp with a static reservation. Seems as though the static device configuration was not fully registering on the network and was limiting access to some of the servers/pcs on the network.
