Canon IR 4570 paper jam in fuser unite
  • tariq65
    • Jun 2010
    • 84
    hi every one i'm faceing paper jam problem ir 4570 paper jam in fuser i'm try all paper treay but bypass treay is good woorking no paper jam any one solved my problem thank you
  • Brian8506
    • 1666
    Re: Canon IR 4570 paper jam in fuser unite
    Whats the jam code
    • tariq65
      • Jun 2010
      • 84
      no code sir. only display shone paper jam location.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        You are not a tech probably!?
        IN service mode you can check a jam code.
        • Brian8506
          • 1666
          What have you done so far?
          • arielcanon
            • Mar 2012
            • 106
            COPIER > DISPLAY > JAM
            Touch an arbitrary jam display screen to see details about the jam.
            (1) To previous page
            (2) To next page
            (3) Jam sequential number
            (4) Jam type
            (5) Corresponding sensor
            (6) To next jam screen
            (7) To previous jam screen
            <No.> Jam sequential number: 1 to 50 (The oldest jam has the greatest number.)
            <DATE> Jam occurrence date
            <TIME1> Jam occurrence time
            <TIME2> Jam reset time
            <L>Location of the jam: 0 - 2 (0:host machine, 1:Feeder, 2:Finisher
            Learning never ends..
            Never give up, where there is a wheel there is a way..
