is it possible to upgrade a imageserver t1 v1 to v2 to install on a imagepress c1+
Re: imageserver t1 v1 to v2
Service position I
(up) for installing system software over Ethernet LANusing cross-over cable)
Normal position (both down):
Service position II
(up/down) for installing
system software from USB-A flash device2 Gigabyte capacity and a data transfer LED)
(this way is a pain to set up)
At the Installation screen, click Next to commence installation. Wait while the contents of CD 1 are copied and installed.
At the pop-up prompt to insert DISK 2, remove CD 1 and insert CD 2. Click Next. Wait while the contents of CD 2 are copied and installed.
Click Next when the message is displayed that the installation has finished successfully.
-Remove System Software CD 2 from the PC.
-Power off the print engine.
-Flip the service switches down to the normal position (see Figure W).
-Disconnect the cross-over cable from the LAN port and the Windows XP/2000 PC.
After you finish installing system software, make sure to flip the service switches down to the normal position.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
BUY the CD's or call Canon Authorized dealer Tech support
Service position I
Service position II
After you finish installing system software, make sure to flip the service switches down to the normal position.Comment
Need Help, I just installed 0SX.8 Mountain Lion and cannot install T1 driver for the Imagepress C1.
I have read thtat there is a driver for the T1 but for v2 software....
How can I upgrade the Imagepass T1 to v2??? Please help... where can I buy the cds... i need everything to do this upgrade please can someone lend a hand? I am in South America so local help will be unavailable.
Another thing... I also have another Imagepress C1 with Imagepass Q1...... Is there a way to Install driver for Mac OS 10.8 ????Comment
also your C1 Needs to be a certain firmware ver.
U will need to call a Canon Authorized Dealer CANON LATIN AMERICA, INC. to order the CD Firmware
where in south america >> see above link for locations
no Q1 Driver for Mac OS 10.8**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
