Scangear Scanning Issue
  • Mitsuku
    • Jun 2025
    [Misc] Scangear Scanning Issue
  • teckat
    • 16083
    Re: Scangear Scanning Issue
    Network ScanGear V2.30 for Windows XP/Server 2003/Vista/Server 2008/Windows 7 (64bit)
    link below>>>>>>>
    http://support-in.canon-asia.com/con...100312802.html
    Caution
    This TWAIN scan driver is a 32bit driver which can only be used with 32bit-compatible applications running on 64bit OS.
    follow posted instructions below for this version also
    use the ScanGear Tool to select the network scanner.
    No scanner is selected during the Color Network ScanGear installation, so this operation is required before use.
    Scangear
    2.71 is usually for Color products
    Caution
    • The ScanGear Tool cannot be started at the same time as the Color Network ScanGear driver.
    • The window displayed may differ according to the operating system on your computer.
    • If the [Windows Security Alert] dialog box appears, you need to register ScanGear Tool in [Exceptions] in Windows Firewall.
    The Color Network Scangear v2.71 has to be installed in Windows XP compatibility mode.
    u can try this>>>
    Setting up Color Network ScanGear Ver.2.71 as Twain Driver on Windows 7 64 bit..pdf
    • teckat
      • 16083
      READ
      Network ScanGear User.pdf
      • Mitsuku
        Hi Teckat,
        Thank you for your suggestions.
        I have installed Scangear V2.30 and got the same error messages as outlined in my original post. I uninstalled and re-installed V2.30, but this made no difference.
        I also uninstalled V2.30 and installed V2.71, but the scanner is not discovered. I switched off the firewall and also tried "specify with address" option, but the scanner was not discovered.
        I note that V2.30 is a 32 bit driver whereas Windows 7 is 64 bit, could this be the reason why V2.30 is not working? I suppose we will have to wait until Canon release 64 bit Scangear.
        As the V2.71 is for colour machines, it didn't work for me.
        Any further help will be appreciated.
        link below>>>>>>>
        Caution
        Scangear
        Caution
        u can try this>>>
        [ATTACH]15979[/ATTACH]
        • teckat
          • 16083
          u need to completely remove all traces of Scangear > to re-install program
          have u seen this post >>
          Scangear driver for windows 7. 64bit
          go to C:\Program Files (x86)\Canon\Network ScanGear select all the .dll files and copy them to the c:\windows directory.
          try it with v.2.30 Network Scangear
          also check in the Scangear /folder>readme file for info
