Performing a Developer Change on the imagePRESS C1 or imagePRESS C1+/ Revised
  • teckat
    • 16084
    [Misc] Performing a Developer Change on the imagePRESS C1 or imagePRESS C1+/ Revised
    Publication has been revised to correct the procedure for Developer Replacement /see page six in pdf.
    NOTE:
    DO NOT perform INISET or INIT after replacing the Starter of the Developing Assembly. If INISET or INIT is performed, the initial value of the toner density signal will be set with erroneous data due to staining that occurs on the surface of the ATR Sensor.
    The ONLY time to perform INISET or INIT on the imagePRESS C1 / imagePRESS C1+ Series is when the ATR Sensor Unit, and the Developing Assemblies (or the starters) are replaced at the same time.
    iPRC1_C1+_Developer Change.pdf
  • jacky_kuo
    • Aug 2011
    • 54
    Re: Performing a Developer Change on the imagePRESS C1 or imagePRESS C1+/ Revised
    Excuse me , Teckat :
    i have a question,
    for example :
    if i replacing starter-c or replacing developing assembly_ c ,
    and i not replacing ATR sensor ,
    but i performing INISET_C or INIT_C ,
    then what's happen on this C1+ ??
    attachment file is not describe what symptoms of error will be happen ?
    could you tell me ??
    In customer side,
    when i only replacing starter or developing assembly,
    i will be do "iniset" or "init" on the service mode ,
    but see your content ,
    i do not know what am i mistake in my procedure ???
    • teckat
      • 16084
      i have a question,
      for example :
      In customer side,
      take it slow and READ the PDF/ click and download it
      if u replace STARTER ONLY >DO NOT perform INISET or INIT
      if u replace with new Developer Assembly unit & Starter>DO NOT perform INISET or INIT
      • jacky_kuo
        • Aug 2011
        • 54
        OH ,
        Sorry , Teckat :
        I re-read PDF file again , again ,
        i think i find that i want to know problem,
        Teckat , thank you answer for me
        because my english is not so good ,
        to read english document and transfer to my language ,
        More or less will not understand some English grammar,
        But still again to thank Teckat dedication to the Forum...
        3Q....
        GENERAL:
        This Technical Publication is to inform the field that Start Developer is now available. Should a technician
        find the need to replace the Start Developer, due to unforeseen circumstances, before reaching the 500,000
        sheets target of durability of the Start Developer, it is imperative that this procedure be followed exactly.
        Failure to do so will compromise image quality.
        • DANIELCANON
          • Jun 2011
          • 187
          ok, teckat y si uno hace una limpieza al sensor ATR, y luego procedo a cambiar los 4 reveladores ( no las unidades); me estas diciendo que no es necesario realizar iniset o init.
          otra dude mas si por algun motivo me veo obligado a resetear la DCON, tampoco sera necesario inicializar los reveladores?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 4999
            • teckat
              • 16084
