ir5870 light copy
  • Apach
    • 157
    ir5870 light copy
    Hello,
    Today, after cca 200 copies of the machine is stopped as if the paper is jammed. After removing jammed paper and restart machine I got up bright copy. Regulation light/dark give me same result. Same copy when I printing or copying.
    5870.pdf
    First page is OK
    Second is light
    and PG test
    Im clean complete device, replaced ATR sensor, Change ITB but problem is same. All conectors is OK and HV also. Please some advice ? Tnx
    There is no stupid question, just stupid answer
  • vigour
    • Aug 2010
    • 1038
    Re: ir5870 light copy
    Change your Outer Secondary transfer roller and check Sec Trans Positioning Assy.
    Do Drum Phase Adjustment
    • Apach
      • 157
      I'm stupid. Resistor on sec. transfer. After replacing all is OK. Tnx
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        You are not stupid.Just a moment for experience.(Nikola Tesla)
