ir5870 light copy
  • zoraldinho
    replied
    Re: ir5870 light copy
    You are not stupid.Just a moment for experience.(Nikola Tesla)
  • Apach
    replied
    I'm stupid. Resistor on sec. transfer. After replacing all is OK. Tnx
  • vigour
    replied
    Change your Outer Secondary transfer roller and check Sec Trans Positioning Assy.
    Do Drum Phase Adjustment
  • Apach
    started a topic ir5870 light copy
    ir5870 light copy
    Hello,
    Today, after cca 200 copies of the machine is stopped as if the paper is jammed. After removing jammed paper and restart machine I got up bright copy. Regulation light/dark give me same result. Same copy when I printing or copying.
    5870.pdf
    First page is OK
    Second is light
    and PG test
    Im clean complete device, replaced ATR sensor, Change ITB but problem is same. All conectors is OK and HV also. Please some advice ? Tnx
